- 71
- 183
- 33
- San Luis Obispo, CA
Hello again all, I'm midway through painting my M35 the Gillespie 24087 that I got from Rapco. They said to reduce it using xylene (I'm using mineral spirits because California is, well... you know.) That said, Rapco said not to put any hardener in the paint because it will darken the color. I really didn't want that because the Vietnam Era OD is brown enough already. I'm considering finding a semi-gloss clearcoat that I can put hardener in and spray over, because the paint I have sprayed scrapes off fairly easily, and leaves light green lines where it gets scratched. On a side note, I also noticed mineral spirits don't evaporate like a normal automotive reducer does. Should I risk the color change from a hardener or just spray a catalyzed clear over it? Help me out here guys. Thanks for your input, anything helps!
