Coolant Filter Question
Andyrv6av8r
455
Spartanburg,SC
I'm about to install a bypass coolant filter on my 923A2. I will be using a Wix 24071 filter with 4 units of DCA. Can I use this filter with standard " Green " antifreeze or should I swap over to the " Red " Fleetguard?
Postman515
44
Clayton, Illinois
I went with the Fleetguard ES Compleat and the #24071. That's the combo Cummins told me to use. Need to also use the test strips.
infidel got me
34
Newberry, Florida
I have been told that you can add supplemental charge additive ,sca available at napa. Then use test strips. You don't actually have to drain your coolant, just to change it over.
The green coolant works fine as long as the charge is good. Let me know ,as I said, this is what a truck repair shop told me.
