napa pto gaskets?
sac
iowa
Hi all,
Getting a winch for my Deuce, and I thought I read that someone had PTO gasket cross over number for napa? I tride the stickeys and search and didn't find them.
Thanks Scott.
P.S. these trucks a addictive, wife is even getting into it.:p
SCSG-G4
PSVB 3003
5,397
3,482
Lexington, South Carolina
They are 49 cents each at FleetPride, but you do have to tell them which thickness you want. Don't need a part number, just tell them six bolt PTO gasket, and the thickness.
M35A2-AZ
423
Tonopah, AZ
You may need more then one. I think they come .010, .020 .030, .050".
Be sure to check the back slash on the gears after you put it on.
It is almost impossible to check it with dial indicator on the truck. But you
can feel it for the most part. Most of the time it is .030"
topo
277
farmington NM
A PTO mounted to tight will give you shifting problems just something to watch for . After you are sure everything is good copper washers under the 6 nuts on the PTO will seal gear oil drips.
