- 9,576
- 210
- 63
- Dickson,TN
I thought I'd start a thread on a little project I've been working on. It's actually a 1974 CJ5 but I've added some military modifications so I thought M38A2 would be appropriate.
The original speedo/gauge combo was inop so I replaced the instrument panel with one from a M715. All the gauges are new Autometer except the speedo, it came from a M35 and reads correct using the stock CJ cable and drive.
The factory turn signal switch was inop so I wired in a M-series switch I had lying around.
I added a set of military shackle mounts to the front bumper so I'd have a pull point and also the ability to use a military towbar.
For the seats I picked up a set of M38A1 cushions and modified the original CJ frames to accept them.
On the rear I used a set of M-series tail lights I robbed off a parts deuce and added a set of reproduction bumperettes from a MB.
To top it off I painted it 3-color camo patterned after the M151 3-color pattern.
Other mods I plan to do is add M-series front turn signals and a jerry can rack. I just can't figure out a good location for the jerry can. The back would be the best but it would hinder the tailgate operation, the tailgate comes in handy hauling stuff around the farm. The light switch has been acting a little screwy so I might also throw in a 3-lever.
I've also found out that a deuce passenger seat is just the right size to fit between the fender wells for a back seat. I just want to figure out a way to make it easily removable when I need the bed space.
