rsh4364
- 15
- 38
- greensprings ,ohio
I have been thinking about plumbing my block heater from bottom rad.hose to a threaded cyl.head flange #1402-8949,think it would work better than running thru heater core.Or plumbing up front near thermostat,would keep all heat in block.Does anyone have thread size on the threaded block off plate? I have 2 tank style heaters,one is kim hotstart# tps151gt10-000,the other is kim hotstart3 sb115100-000,which is very heavy duty.Both are 1500W,one has check valve so cant be back fed. And I also have a temro 1000w freeze plug heater which I would use when really cold.None are installed yet.
