NITEFARMER
- 0
- 0
- Shenandoah Valley / VA
Hello all,
I'm new here and need some help from you experienced guys. I have two M35A2's and both are doing the same thing. So either I am the most unlucky Deuce owner or this is a common problem. Neither of them are getting fuel to the injectors but both have fuel at the pump. The water truck was running fine and one day taking water to the cows it just quit. Thinking it was a filter problem I changed them all including the in tank pump. Did not help and I gave up. Thinking the injection pump was bad I started looking for a IP and ended up buying another truck for not much more than a pump. It ran great but needed a clutch and one rearend. That was several years ago and this past weekend I decided I was going to start it up again. It started and revved up to I'd say about 2000 rpms. I immediately pulled the kill but it did nothing for about 5-10 seconds and slowly started dying out like it was running out of fuel and stopped. So I went out and checked the linkage to be sure it was not stuck wide open and everything appears to be working freely. Tried to restart and nothing. Opened bleed screw at filters, good fuel. Cracked line at IP, good fuel. So cracked two injector lines at injectors and tried again, no fuel. Disgusted and not believing I had another truck doing the exact same thing, I googled it and ended up here. From what I've read it seems a button may have come off in the pump not allowing the HH to work. Since I have not worked on these pumps(only Roosa-Masters on tractors), I need some detailed advice on how to check for and repair this. As well as any other ideas or advice as to what could be causing this problem. Thanks in advance for your forum and help.
