2015 la rally swap/sell/trade
goldneagle
1,476
Slidell, LA
To anyone who asked me about buying a Roboimpact driver from me at the LA Rally please contact me ASAP if you want one. I have less than 10 left! You need to make payment in advance in order for me to set one aside for you.
juanprado
3,158
Metairie/La (N'awlins)
LA Rally goodies
Stuff I have available:
A.) mich xzl 16x20 85% $75
B.) 2-mich xzl 398-85-20 35% $40 each
C.) 3 rubber one piece 20 inch run flats $30 each
D.) 20 inch hutchison bolt together bead lock $20
E.) Regular length non winch M939 hood prop $20
F.) CTIS signal generator M939A2 speedometer cable pass through $25
H.) 10 Haltec H-41 large bore tire spuds for 5 ton rims 13/16 hole $30
I). Wrecker metal spotlight fixture with good bulb $65
J). used 40 budd nuts and caps 1 1/2 ,tan carc, good threads, 20R & 20L, Set $60
K). set of 2 tan used 3 hole shackle mounts/pins/ and u shaped shackles for rear of a truck or bottom bumper M939 mount $75
L). Water hose 6 ft with 1 1/2 male camlock fittings on each side $20
M). M101 headboard brackets $10 set
N). M101 stave uprights long and short $5
O). M101 rear right gate brackets (supply your own wood) set $10 (will make complete gate)
P). M939 T- Filter spin on base ( universal 1 1/8 x 16 can be used for any oil or hydraulic application- NOT FUEL) $10
Q) 4- new 5 ton green combat wheels with 3/4 studs, new torque nuts, Tire spud, and large bore 45' valve stem (valve is military nos but not m939 specific valve) in wooden crates. O-rings in box, expect them to be bad pinched by rim in shipping and be pleasantly surprised if you have good ones $125 each
R) 12- lb freon 12 cans $21 each SOLD SOLD SOLD
S) M939 air intake mushroom cap $15
Pictures available, please send pm with email
pay it forward
11x20 ndt on 5 ton rim 10 hole. Tire good for spare or offroad or fixed trailer 20% weather checked. Bias tube and flap in it. Holds air fine. Given to me by another member. No longer needed. Free to a good home :)
Jeepsinker
470
Dry Creek, Louisiana
I am looking for 3 good 11r20 NDTs if anyone has any. Doesn't matter what rim they are mounted on. Unless someone has some G177s they want to part with REAL reasonable...
profo
74
jeanerette,la
12 freon is freon still in can?
juanprado
4 Star General
Join DateSep 2011LocationMetairie/La (N'awlins)Posts1,760Feedback Score73 (100%)
[h=2]
LA Rally goodies[/h] Stuff I have available:
juanprado
3,158
I have 12 1LB cans of Freon R12. I sold parts for 25 years and squirreled some away for 80's 3/4 Suburbans I had with front and rear A/C but those are long gone now.
Freon R12 is for older vehicles not the current R134 as they do not mix.
roalcoal
poplarville ms
I have 12 1LB cans of Freon 12. I sold parts for 25 years and squirreled some away for 80's 3/4 Suburbans I had with front and rear A/C but those are long gone now.
Freon 12 is for older vehicles not the current R134 as they do not mix.
Make sure you check for epa certification cards don't want to get in trouble
juanprado
3,158
I have a set of 12 Goodyear G177 Steel belted Radial 11:00 x 20 mounted on 10 hole budd pattern lock ring wheels with flaps and radial tubes. Tires are like new with high tread. No leakers, no plugs or repaired tires. 2 tires are slightly cupped that were on steering axle from bad shocks that I rotated to back and are fine in any back position.
$125 mounted on wheel with flap and radial tube.
Buy all 12 and I will throw in an extra tire and rim that the outer tread block had been cut with debris but perfectly serviceable for spare tire. Tire sidewall and body not cut, just outer tread block gouged.
Tires in Slidell at GoldnEagle's place maybe 20-30 miles? Can be loaded with forklift- negotiate with Zev- operator's fee ;-)
a175
Lake Charles, LA
I'm not seeing very many M1008 parts floating around in this thread. Anybody know what might show up?
If I'm able to make it, I'll be bringing stuff that came with the truck but that I have no use for. One of those goose-neck tailgates and the rear bench seat to a chevy sumthin (if I can find it).
If anyone is in the Lake Charles area, I could sure use some assistance getting this truck road-trip ready. Just let me know what you'll need in return!
justinhcannonATgmailDOTcom
337 2o2 9856
