Cucv Hard Start
Macmatrix
MI
I have a 86 m1008 that cranks very slow (like dead batteries) when you first turn the key. After turning the key after a minute or two it will crank fast enough to start. After it is warmed up it will start right up. The truck has good batteries, new battery cables,new positive starter cable, doghead relay mod and a rebuilt starter.
acesneights1
24
20
CT
I have had a few 12v 6.2s do that . Something was wrong with the starters in them.Never had it with a 24v though. Also sometimes the ground cable can be bad. I actually found a bad cable using a battery load tester. Try load testing the batts using the cables (not hooking directly to the batt). The cables should carry a decent load. It the batt tests good hooked directly but not when testing it via the cable might be your probably.
firefox
General
1,844
52
Berkeley CA
You didn't mention any thing about glow plugs. Did you check to see if they are
functioning normaly? Is it possible that they are responsible for the parasitic load
on the batteries. Just throwing a few things out there for the experts to comment on.
Assel
Germany Schwarzwald-Baar
Im 90% sure its a dead battery / bad connection, if your Batteries are 100% good it could be a messy connection point right under that small plastic cover behind the batteries where all the thick cables head to.
I once had exactly those symptoms on a 87' BMW e30 , if started cold it was like "tok...tok....tok...tok" after 4-5 attempts (each one about 20 sec of cranking, on each additional try it was faster) it would start. Warm it fired right up when the key was turned. Replaced the Battery and never had any more problems.
rustystud
3,389
Woodinville, Washington
Why would the truck start right up after running?
The truck is already warm and the fuel is already at the pump. Warm engines always turn over easier. Cold oil is like molasses, warm oil is like water. I also would check the battery ends for corrosion. My CUCV had great looking cables. Then I unwrapped the ends and found mass corrosion eating the cables. I ended up replacing all my battery cables with 2/0 cable.
