Shirehorse
- 19
- 18
- Mantua, OH
x2Looks like you gelded your stallion this week too.
You've done as much work in that thread as you've done on the truck. Nice write up. That thread doesn't pertain to me but it's been a good read all the same. There's a lot of good general brake information in there.Continuing the air brake saga. Old brakes...off. New brakes...on. Ready for hubs, drums and axles to go back on. See the progress in posts 33-36 below...
http://www.steelsoldiers.com/showthread.php?140055-M809-series-(M818-Air-Brake-Retrofit/page4
Thanks! It's been quite the haul. Luckily those backing plate rivets are done The plumbing will be tedious, but not hard. The front brakes will just be a swap with the drums/hubs being the only heavy part.You've done as much work in that thread as you've done on the truck. Nice write up. That thread doesn't pertain to me but it's been a good read all the same. There's a lot of good general brake information in there.
I gave my fuel canister a soak in muratic acid, painted it, installed new brake lines and a new fuel filter. Alas, she won't restart. See my help thread here: http://www.steelsoldiers.com/showthread.php?140897-NHC-250-No-start-fuel-problem
Where and part numbers please??View attachment 564638View attachment 564639View attachment 564640View attachment 564641
Get a screw on filter kit.. Cheap, and worth not having all the bravo sierra to deal with.
Mine was a rusty ole mess....
I think I have a small pile of those barbed fittings, depends on ID of hose butsWhere and part numbers please??
looks like 1/2" IPS on the threaded side.
If you are not in an area that uses road salt the steel nipples will be fine
but if you are in a salt area I would go w/ solid brass nipples everywhere.
Good job!
