M35A2W/W fuel line
wiggall
151
Lenore, Id.
On the way back from a car show. I developed a leaky fuel line. I think that it was a return line, as the engine did not miss a beat, just went through a bunch of fuel. I found the leaking line, and replaced it. I filled the line with fuel. now I can not get the truck to start. any ideas of what I need to do?
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Which line was it you replaced? Did you bleed the fuel system after? I would start there.
Good to see you posting again.
wiggall
151
Lenore, Id.
Got the Right fuel line replaced! To be on the safe side, as I had already unhooked the end of the other wrong fuel line I resided to go ahead and pull it to check it out! It was ok put the new RIGHT FUEL LINE and bled the fuel system! THE BEAUTIFUL BEAST is running with no leak!
