bprzyw
- 418
- 63
- Moscow,Pa USA
Hi all. Currently have a 1970 M35A2, owned her about 25 years now..... have not ran it in a year and a half. Went thru post inspections, checked all fluids, filters (removed mice nest in air filter) put 25 gallons fresh diesel, 2 refurb group 31 deep cycle marine exide batteries, and presto, purred like a kitten. Pulled her out of the barn. Flushed and refilled brakes with Dot 5, bled all lines. Took her for a bit of a ride today, maybe 2 miles on my property, let it idle in driveway while checking / rechecking tire pressure. Noticed white smoke from engine, quickly turned her off. now there is oil and steam (?) blowing from the passenger side behind the air cleaner canister up under the intake assembly. Seems like a air hose. just in one spot, is there a freeze plug there? Sounded like steam blowing, smelled like antifreeze.....But also oil all over that side. It has a White LD 465 (on engine tag) Multifuel. Common issue? or something major? I had thought head gasket, but its coming out of a round hole, i could feel it, but could not touch the engine as it was HOT. Help please.
Thanks
Bernie
Thanks
Bernie
