catskillpond
- 1
- 16
- wurtsboro ny
Four months ago I purchased surplus marker lights on line. They were not cheap made ones they were all aluminum had rubber boots and good leads,installed an additional marker and turn signal light on each outside corner. Everything worked fine till last week flasher went replaced that. Turn signal arm went next, took that apart the contacts and wires inside were shorted out.
I tried service drive check headlights and park lights breaker inside of service switch starts clicking.
Disconnected all the wires running to front and rear turn signals tested from the turn signal to each light wire, nothing shorted same with headlights and parking lights then the dash lights. After three hours I noticed one of the new marker lights the wire boot on the back was cracked [had these separated when checking main vehicle lights] checked the others 6 out of ten were all deteriorated seems these got the sunlight. Did not think it would be new lights causing the problem still took one apart it seems the plastic insert that holds and insulates the hot lead from ground on the socket had cracked in small pieces and shorting to ground. The other five had the same problems the worst ones were on the front I'm guessing the vibration from the engine or possibly heat from bulb. Still had three new ones in the box under a magnifying glass you could see the cracks in the plastic insulator.
