blacke
- 0
- 1
- Gardnerville, NV
I believe this is my first post and I hope I don't screw it up. I'm going through my M936 fixing mostly small things and this site has been a technical marvel with a ton of useful information, however, I have a problem that I can't find a previous post for, and I also haven't been able to find the answer in any of the TM's I have. I'm trying to figure out how the cable roller guide that sits on top of the rear 45k Lb.winch comes apart. The problem is the section on top with the rotating cup holding the cable pulley wheel is frozen. I have taken the only bolt I can see holding the two pieces together out and have been trying to separate the bottom section with the cast in cup from the piece holding the pulley wheel that's supposed to allow the wheel to rotate when winding or unwinding the cable.. I've applied some serious force (2 ton) and it does not want to separate. Has anyone had experience taking this apart and if so, can you tell me how it's done before I break something?
