Keith_J
- 1,328
- Schertz TX
If the seal isn't leaking, there is no need to change it. Seals ride on a layer of oil, as long as they seal, they shouldn't be changed.
I used the NAPA Service Tools steering wheel and crankshaft puller tool set, UPC number 14994 02291. This is a KD Tools 2291.
Not only does it pull the damper, it can be used to install. The threads on the puller match the crank threads. The hex end is reduced off the threads so it inserts into the crankshaft, then you can use the puller end with an adjustable wrench as a nut to pull the damper onto the crank. Use washers as needed with grease, it will go on.
It is an affordable tool set.
