seek
- 0
- 6
- Mocksville nc
I got time to run my generator some using the front outlets only for load since my electrician has not set me up yet. I wanted to just run to be sure my rings were seated.
I got it tuned in using a heater and a big work light on the other outlet. I decided I wanted to add more load and in doing so I blew both fuses. That can be bad because you are likely to burn up your regulator with no load and that's what happens when your fuses blow. So beware and have extra fuses. Lesson learned without damage.
I found some fuses at Los that are marked 15a 250v packaged for microwaves.
