Mike82ndABN
- 10
- 0
- Tampa/Florida
I have a natron PCB 6110 01 292 053
i was charging batteries and tried to start again last night. As soon as i moved it over to run, it started clicking non stop. I'm assuming if I had a full charge it would have engaged the starter all by itself. This was in run. Not in start.
Is this a bad PCB. Could a bad ground cause this? Can I open it and clean the relays, maybe it welded the relay shut and it's stuck.
Only thing I've done recently is change headlights and charge batteries (still won't hold a charge).
