- 2,113
- 562
- Davis County, UT
Welcome to the world of deuces! I hope you find a good one. Even though you're passing on this one, I did have a few comments:
http://www.oshkoshequipment.com/products/detail/21/728/15.580R20-Michelin-XL-Tire-90-plus
I also agree with the square pipe blocked suspension on the rear axles not looking safe.
Example:
http://www.bigmikesmotorpool.com/products/m35a2-correct-winch-shear-pin-7538740
I disagree, those look like Michelin XLs. Michelin XL's have that tread pattern. If I had to do a wild guess, I'd say 15.5/80R20 Michelin XL (~46.5" tires). Example:Look like Goodyear's
Definitely a bolt. As far as I understand, the M35 shear pin is typically made of aluminum and is held in by cotter pins on either end.Is that a shear pin or bolt?Attached: Picture of winch shear pin under my truck
Example:
