Mike82ndABN
- 10
- 0
- Tampa/Florida
shouldn't it be double?Hmm if it's 300 12v then it's half that at 24 volt
No.shouldn't it be double?
If this is the same KeithJ from another popular board, then I know you know your stuffHad one fail at less than 100 amp and 28 volt. Voltage doesn't matter if you don't make or break under full load. Current is Current when made. THere are better switches.
You found meIf this is the same KeithJ from another popular board, then I know you know your stuff
x87
