nyvram
- 1
- 0
- Franklin/TN
So I have a few obvious questions that I didn't see 100% in the FAQ:
1. It has 315 75 16 tires on it. It appears to be the OEM rims so can I just purchase and put on the regular sized tires listed in the FAQ? Is there a good tire brand/model I should look for or more importantly..any I should avoid?
2. Towing. I'll be using an 06 Sequoia and the larger UHAUL trailer (with brakes) and the distance is about 150 miles although there is a BIG hill along the way that I'll probably be going about 35mph up and 35mph down. Toyota is rated to 6700lbs. Will I be ok if I go slow? Anything to look out for when selecting a trailer from uHaul?
3. I see alot about the starter relay/mod/ignition. Assuming I just want to go the simple route for now and get the igntion working properly, should I follow the 'mod' advice or what exactly is the most straightforward process for this?
4. Assuming we replace the glow plugs and the get the vehicle started and running with new tires, what else is MINIMALLY required initially to make this road-worthy? It won't be going on fast highways or the interstate, we just want a good road worthy vehicle to tool around in.
Very excited about it.
Thanks and be gentle..I'm trying to learn all I can from this site and not bother y'all with questions you've answered a million times.
