- 1,708
- 1,780
- Nova Laboratories, WA
So, I noticed my M934 starting slower and slower... and noticed the gauge was in the red...
Went to go check the alternator and both belts were gone...
Then I noticed the pulley was loose...
Pulled the alternator, and realized the pulley and shaft index points for the key were pretty hosed... I shoved a larger key in there and reassembled.
There is a slight wobble (out of round) from the pulley, so that's issue #1...
Then, I put it back in, and was tightening the electrical connections, and one of the screws sheared off... leaving me no way to connect anything to it.. Tried soldering to the brass terminal.. no luck... even tried drilling it... no luck....
So, I start looking for replacement alternators.... Holy Mother of God! $800?!
I could replace the shaft, pulley, and assembly for about $200
BUT!
I see people replacing alternators with COTS units.... which are significantly less....
This got me thinking... I have a spare alternator for my M1010, which is 100A, 28V, and is same company and same mount style (J-180?), is there a reason it won't work? I will have to get a new pulley for it, but a new pulley beats $800 on an alternator.....
OR.. I could just WELD the pulley onto the old alternator, and replace the broken screw 'area' for ~$50 but I'd be worried about the alternator, as that woodruff key is used for a reason.. (I think?)
ETA M934A0 - NHC250
BUT!
ETA M934A0 - NHC250
