Air Tank
JohnnyBM931A2
Crystal Lake, Illinois
As part of my ongoing project to add an additional air tank for my 1" impact gun, I ran across a slight problem. While looking for a place to "tee" in for the air line, I found an unused port on my lower air tank. Problem is, the plug is stuck in there solid after 24 years of not being moved. I tried wrenching on it with an allen key and pipe, as well as using penetrating oil and letting it soak in.. No luck. Would it be ok to hit that plug and bung with a MAP gas torch to try and loosen it? I just don't want to risk any weakening of the metal on such an important component. And does anyone happen to know what thread those plugs are? 1/2" is too small, and 3/4" is too large. I'm guessing 5/8npt.. Is that even a size? :confused:
Any help is appreciated :)
JohnnyBM931A2
UPDATE: I fail.... lol. So I decided to bite the bullet and hit the plug with my MAP torch. After only about 15 seconds worth of heat, it came out easily with a hand allen key. The fail part came in when I looked at the plug after it came out.. It's 1/2" NPT, like all my other fittings :doh: It must have been all the paint buildup, or maybe just an optical illusion... lol.
Everything worked out in the end :)
73m819
329
gainesville, ga.
When putting heat to a air tank, MAKE sure that the drain petcock is OPEN and WORKS (not plugged), a air tank WILL EXPLODE, and does not take much heat to cause the event.
152
Birdsboro Pa.
Check the threads for rust and pits. You don't want to rely on pipe dope to create a good seal. You could chase the threads with a tap to freshen them up. Be careful not to go to deep.
dmetalmiki
2,036
London England
All my trucks have quick fit fit hose conectors after the drain taps. Also a glad hand adaptor and long line with connector for tools etc. The additional tank is usefull (if like me) you have air power steering fitted. (deuces).
My 1" impact for wheel nuts works just fine out of the glad hand. (emergeancy side (red)).
Andyrv6av8r
458
Spartanburg,SC
I added a 12 gallon reserve tank and tee'd it in at the wet tank after the dryer with a manual valve in the cab. I keep it pressurized at full pressure and it's there if I need some extra air.
JohnnyBM931A2
Yeah I added a 7 gallon Manchester tank on top of my rear toolbox. It is painted to match the truck, and I think it looks pretty good.. Very industrial. Now that I was able to get the plug out of the air tank on the truck, I piped everything in. Everything between the factory air tank and my air tank is 1/2". I also put a ball valve in after the factory air tank, so I can shut off the line to my new tank when I want. And finally, I did put a separate 1/4" drain line in for the new tank so I can drain the water out.
I think it should work out well :)
Andyrv6av8r
458
Spartanburg,SC
Ya got a picture of that and where you mounted it
Sure. Valve is beside the seat and keeps 125 psi in it. Tank is located beside the dryer up out of the way. I lost my air compressor too many times and wanted some " extra " air in an emergency if needed. If I get in the truck with empty tanks, I open the valve and get 45+ psi in all tanks at start up. I'll close it and open it after I get on the road to refill it. Plus it gives me a little extra capacity from the red glad hands if needed.
