JohnnyBM931A2
- 1
- 18
- Crystal Lake, Illinois
As part of my ongoing project to add an additional air tank for my 1" impact gun, I ran across a slight problem. While looking for a place to "tee" in for the air line, I found an unused port on my lower air tank. Problem is, the plug is stuck in there solid after 24 years of not being moved. I tried wrenching on it with an allen key and pipe, as well as using penetrating oil and letting it soak in.. No luck. Would it be ok to hit that plug and bung with a MAP gas torch to try and loosen it? I just don't want to risk any weakening of the metal on such an important component. And does anyone happen to know what thread those plugs are? 1/2" is too small, and 3/4" is too large. I'm guessing 5/8npt.. Is that even a size?
Any help is appreciated
