orgnal
- 4
- 18
- Denver, CO
Is it possible to switch out the military seats for after market seats? Would a comfy car seat fit in the space available? Has anybody done this? if yes, can you please share pictures? Thanks in advance.
Just finished replacing all 4 of my seats last night. I'll post some pics for you later tonight.Is it possible to switch out the military seats for after market seats? Would a comfy car seat fit in the space available? Has anybody done this? if yes, can you please share pictures? Thanks in advance.
Very easy... just 4 bolts. You'll need a 1/2" socket and 1/4" Allen wrench. Slide the seat all way back and unscrew the front bolts. Slide the seat all the way forward and undo the rear bolts. Or do it in the reverse order. Does not matter.How involved is it to remove the original style driver seat frame and replace it with the newer high back frame/mount.? I've considered going with different seats, and the driver seat is my only hesitation.
I need that thermal stuff for MN winter! Spendy as **** from what I've seen.Here are the seats that I put in mine. I'm not sure if he has any more, but PM Suprman if you are looking to purchase.
View attachment 586551View attachment 586552
Mine came from Suprman, but I got his last set of doors. Top and rear curtain are going on this weekend. Just need some pipe insulation.I have the cold weather top stuff minus the doors but the regular doors work fine. Unless you are short you cant see out the door windows anyways they are too low.
