It's getting close to the end of the warm weather season and I am wanting to hit the many red plastic capped grease fittings found around the truck. I also just replaced a tore zipper seal on the front hub and most all of the grease was lost during the process(what a messy job!).
Is there a particular type of grease that can be found at tractor supply for this? Is the same grease used in the front hub okay for the many other grease points?
Thank you for any advice.
