brazengoat06
- 2
- 16
- Tulsa, OK
On reasembly is one suppose to load the spindle tube bushing with grease?
Way to go, I see you got the pics up!
Same way I did itFunny enough I tried to go back and find the tm and couldn't lol I used a slide hammer and the screw on adapter of the two jaw puller without the jaws. You insert it into the inside of the tube on the other side of the retainer and pop out the ring. I used no parts
There is one in the M35 section and it might be a sticky, that is very good with pics. They are really close to the same with the differences being some bolt and nut sizes, a different seal or 2, air brakes verses hydro brakes. I've done both size trucks. Oh yeah the 5 ton parts are much heavier.This needs to be a sticky !!
