CUCVLOVER
- 9
- 38
- west Tennessee, just outside Milan
Rear diff oil change
I finally got around to changing the oil in the rear differential and checking out the chunk. I got the truck in my dad's shop on concrete and started working. I had my new gasket, my oil, permetex and tools. I cleaned up around the cover before I started pulling the bolts. I tool the bottom bolts out and started my way up and that drained the oil. Once I had most of the oil out I took the cover off and started cleaning out the housing.
Then I cleaned up the cover. I used a knife to scrap the housing and a side grinder and a worn out flap disk to clean the old gasket and such off the cover.
Then I started putting it all back together. I put permetex on the cover, then stuck the bolts through it, then the gasket, then I put permetex on that, then bolted the cover on.
Then I started to fill the oil and had a issue. The oil fill plug was broken off. So I ended up loosening up some of the cover bolts and stuck my plastic funnel in the top and started tightening bolts and pouring in the oil. I filled the oil and all was good.
Thank you all.
Thank you all.
