Received and installed my new heated Truck Lite LED headlights
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Can't wait to see what they look like after it gets dark out
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Also painted my new muffler from Floridianson with high temp black grille paint. Went a bit overboard and did like 6 coats. Looks sweet. Also pulled off my top pipe to paint that, and noticed some rot around the mounting flange. Probably still fine to use once it's clamped in place, but.... I used it as an excuse to order a new one
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
My new gaskets and clamps should be here on Friday or Saturday, and the new top pipe will be here Monday. So weather permitting, I will get my new muffler and gaskets installed this weekend, then paint and install the top pipe Monday after work. When I pull the old muffler off, I'm also going to take a moment to give the muffler mount frame another coat of green paint. I will also hit the lower exhaust pipe and flex joint with the same high temp paint as the muffler and top pipe. I don't think I can get all of it when it's still mounted in place, but I can get everything that anyone will see. It will certainly be better than it is now.
This weekend my new silicone hoses for the aftercooler coolant pipes should arrive. That is my next big project after the muffler is done.. Draining the coolant, replacing those hoses, installing my block heater, then putting in fresh NAPA coolant.
And THEN, after that is finally done... My next NEXT big project will be chipping off the peeling paint under the cab, sanding it, priming it with the rust killing primer, then bedlining it. It's not like anyone is going to see it, so I could care less if the bottom of the cab is black instead of green. I might eventually do the firewall behind the engine, but that looks ok for now. My cab is currently rust free, with the exception of some very minor surface rust around the edges of the floor. I want to keep it that way. A difficult task, given the amount of snow and salt that we deal with around here during the Winter, but I will do my best.
