gimpyrobb
dumpsterlandingfromorbit!
- 27,786
- 770
- Cincy Ohio
.....obviously it was info posted on a extreme condition with lots of heat built up and power applied and a engine builders opinion with lots of experiences. to help with the discussion show me a counter argument instead of rhetorical question.....
I haven't had too many of my MVs run hot, are you having issues that make you want to modify your truck? I just don't see a reason to mess around. I've flat towed an 813 from Indy to my house and didn't have issues with the truck running hot, I don't understand why the mod is needed, but I don't understand lots of things. If you just want to tinker, I understand that!
On the egt side, have you done any of the air filter mods that some of the others have done? Helping air in to the motor helps a lot. I guess you could put an aux radiator over the tool box and plumb the trans lines to it, seen it done a lot for rock crawlers.
