48cj2a
- 34
- 28
- Central, IL
I reconnected the battery terminals and I moved the disconnect from the front battery negative to the center battery negative. I no longer have the 12v on the orange GP terminals of the GP Relay with the disconnect in the open position.
I tested the Push Button GP Relay Button and get the 12v on the orange GP feed as required.
I needed a second hand to bleed and prime the fuel system so hopefully can attempt that tomorrow after work. Can fuel be pulled through the system if I connect a pump to the IP return line and get a better prime and air bleed?
I did try about 4 cycles of starting with the new manual switch but no firing as of yet.
I want to confirm this...
Post #25 - They were all 2.8ohms during the #19 troubleshooting steps.
Post #45 - Glow Plugs all test nice and bright with the test light ground on the the GP terminal and the touching battery + with the probe.
Is there any other tests to confirm good or fried?
