Agree, the banks kit I just installed uses the stock fuel pump but replaces the stock fuel pump adapter plate with one that has a 3\8" tube welded to it for the oil return.You can get away without an electric fuel pump if you have a bung welded into your oil pan. That way the mechanical pump can stay and the oil is drained to the bung from the turbo
Wow that really looks good! Did you ever get the winch problem figured out?Andddd....Bedlined
