mikey
- 39
- 28
- Lake Como, PA
I just picked up an 86 M1009 in what appears to be very good condition. I drove it home about 500 miles with no issues except Gen 2 light coming on. I'll test the high side battery and if that passes rebuild the regulator on the high side alternator ASAP.
I've read the -10 tm and will read the rest as necessary. Right now I'm reading as much as I can in the CUCV forum.
One issue I'm having is the alignment. From what I'm reading this could be a number of factors, but assuming its nothing major in the front end, is it true that most big name alignment shops (Jack Williams by me) should have no problem doing an alignment on the M1009 if I check it in as a K5 blazer?
Thanks!
Mikey
![10625060_10205593929076435_1637026455527523885_n.jpg 10625060_10205593929076435_1637026455527523885_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411726-848e1d04ab0ac5f103260706f17c8316.jpg)
![12241245_10205593928316416_6032021780310971091_n.jpg 12241245_10205593928316416_6032021780310971091_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411727-f5cba657d1594f56c7cdd59094cb5239.jpg)
![12418109_10205593929876455_5416176913369887036_n.jpg 12418109_10205593929876455_5416176913369887036_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411728-3660df18103d6625313af0d9c3b8a21d.jpg)
![12495021_10205593930116461_8453551101457363480_n.jpg 12495021_10205593930116461_8453551101457363480_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411729-b5558472b2f8998d86160229112a6b3f.jpg)
![12509251_10205593928156412_5124342174600963302_n.jpg 12509251_10205593928156412_5124342174600963302_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411730-30215187a216f1381d87229165436b1e.jpg)
![12510291_10205593929516446_3009049288665748765_n.jpg 12510291_10205593929516446_3009049288665748765_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411732-067c6d842b761abe18f55f528a48c5b7.jpg)
![12541163_10205593927476395_3095613954985419297_n.jpg 12541163_10205593927476395_3095613954985419297_n.jpg](https://www.steelsoldiers.com/data/attachments/411/411733-776f6b3ecaad163c8039bf4d48172144.jpg)
Thanks!
Mikey
