MEP-8xx series Replacement parts
Daybreak
2 Star Admiral
1,522
774
Va
MEP-802/803 Filters
MEP-802A ONAN DN2M 2-cylinder engine (Lister-Petter LPW2)
MEP-803A ONAN DN4M 4-cylinder engine (Lister-Petter LPW4)
MEP-802A Filters List, MEP-803A Filters List
Oil Filter Spin-On (FILTER ELEMENT,FLUID NSN#2940-01-154-5127 )
Prefer WIX 51374, Napa 1374, works also(WIX 51348, NAPA 1348 ), FLEETGUARD LF3335, BALDWIN BT223, DONALDSON P550335, FRAM PH3614, PUROLATOR L10241, CHAMP PH2835
Fuel Filter cartridge (FILTER ELEMENT,FLUID, CARTRIDGE NSN#2910-00-099-5467 )
WIX 33348, NAPA 3348, FLEETGUARD FF4012, BALDWIN PF-847, DONALDSON P13, FRAM C11941, PUROLATOR F53121
Fuel Filter, Spin-On Fuel/Water Separator Filter (FILTER,FLUID NSN# 2910-01-376-5666 )
True Military filter with drain connector 85285-F
Alternate replacements, with bottom drain, but, factory drain with hose does NOT connect WIX 33472, NAPA 3472, FLEETGUARD FS1251, BALDWIN BF1226, DONALDSON P550248, FRAM P8043, PUROLATOR F64424
Air Filter (FILTER ELEMENT,INTAKE AIR CLEANER NSN#2940-00-934-7989 )
WIX 42276, NAPA 2276, FLEETGUARD AF435KM, BALDWIN PA1960FN, DONALDSON P181050, FRAM CAK256
There are many other filters out there. The best is a quality filter for a good price.
Oil Type
15W-40 Heavy Duty Diesel Engine Oil
Same thing here, whatever oil you want to use.
Coolant
Heavy Duty Diesel Type
MEP-8xx serpentine belt
Goodyear 4040355 Gatorback Serpentine Belt, Gates Micro-V AT K040355
MEP-8xx Fuel Tank Drain
Fuel Tank Well Nut A3816
MEP-802A 5kw generator
The military is currently using Optima Yelloptop 51R batteries x 2 in series for the 24 volt system
MEP-803A 10kw generator
The military is currently using Optima Redtop 34/78 batteries x 2 in series for the 24 volt system
Guyfang
26,681
Burgkunstadt, Germany
Mike,
This info should be put into an Excel file, and constantly up dated. Too many people reinvent the wheel every time someone new starts looking for parts. A list for every type of gen set by model.
The same with manuals. I have the newest Power generation CD, and asked a moderator if we could remove the manuals that are in the forums manual bank. Got no reply yet. I would replace the manuals by type and model. There are NEW manuals, along with changes to others.
JRM
Brightwood, Oregon
Mike,
+1 on a sticky with this info posted as many of us are picking up late model MEP units and entering this site as newbes :)
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
Making a pretty good collection of supporting information for your MEP-8xx units
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
I would suggest that anyone which gets a MEP-802A or MEP-803A unit goes through and preps it for use. One thing to do is to run the unit with a good load. Remember, the convenience receptacles are 10 amp. The reset for that is right inside behind the front panel. A real load to work the generator will need to be hooked to the lugs.
Working a generator on a load bank
Good luck
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
The MEP-802A DN2M-1 2 cylinder engine.
The MEP-803A DN4M-1 4 cylinder engine.
Almost everything is common between the two engines.
filters, pumps, gaskets, pistons, rings, starter, alternator, front panels, gauges, and other items.
Makes it easier to find parts with commonality.
as Guy would say, its in the TM parts manual UOC (Usable On Code) :)
Daybreak
2 Star Admiral
1,522
774
Va
MEP-802A and MEP-803A manual information
MEP-802A manuals you should have
TM 9-2815-252-24_____ Diesel Engine Model DN2M
TM 9-2815-252-24P____ Diesel Engine Model DN2M-1 Parts
LO 9-6115-641-12____ Lubrication Order
TB 9-6115-641-13____ Winterization Kit Tech Bulletin
TM 9-6115-641-10 ____ Operator's Manual MEP-802A
TM 9-6115-641-24____ Maintenance Manual MEP-802A
TM 9-6115-641-24P____ Maintenance MEP-802A Parts
MEP-803A manuals you should have
TM 9-2815-253-24_____ Diesel Engine Model DN4M
TM 9-2815-253-24P____ Diesel Engine Model DN4M-1 Parts
LO 9-6115-642-12____ Lubrication Order
TB 9-6115-642-13____ Winterization Kit Tech Bulletin
TM 9-6115-642-10____ Operator's Manual MEP-803A
TM 9-6115-642-24____ Maintenance Manual MEP-803A
TM 9-6115-642-24P____ Maintenance MEP-803A Parts
Maybe not the physical copy, but the PDF files are out there.
brazengoat06
Tulsa, OK
What are you all using when replacing the fuel supply rubber portion that clamps onto each pump. I have one with a crack. By the looks of it not sure if I can just use hose or if I have to replace the entire supply line. Couldn't locate the parts TM.
