MEP-802/803 Filters
MEP-802A ONAN DN2M 2-cylinder engine (Lister-Petter LPW2)
MEP-803A ONAN DN4M 4-cylinder engine (Lister-Petter LPW4)
MEP-802A Filters List, MEP-803A Filters List
Oil Filter Spin-On (FILTER ELEMENT,FLUID NSN#2940-01-154-5127 )
Prefer WIX 51374, Napa 1374, works also(WIX 51348, NAPA 1348 ), FLEETGUARD LF3335, BALDWIN BT223, DONALDSON P550335, FRAM PH3614, PUROLATOR L10241, CHAMP PH2835
Fuel Filter cartridge (FILTER ELEMENT,FLUID, CARTRIDGE NSN#2910-00-099-5467 )
WIX 33348, NAPA 3348, FLEETGUARD FF4012, BALDWIN PF-847, DONALDSON P13, FRAM C11941, PUROLATOR F53121
Fuel Filter, Spin-On Fuel/Water Separator Filter (FILTER,FLUID NSN# 2910-01-376-5666 )
True Military filter with drain connector 85285-F
Alternate replacements, with bottom drain, but, factory drain with hose does NOT connect WIX 33472, NAPA 3472, FLEETGUARD FS1251, BALDWIN BF1226, DONALDSON P550248, FRAM P8043, PUROLATOR F64424
Air Filter (FILTER ELEMENT,INTAKE AIR CLEANER NSN#2940-00-934-7989 )
WIX 42276, NAPA 2276, FLEETGUARD AF435KM, BALDWIN PA1960FN, DONALDSON P181050, FRAM CAK256
There are many other filters out there. The best is a quality filter for a good price.
Oil Type
15W-40 Heavy Duty Diesel Engine Oil
Same thing here, whatever oil you want to use.
Coolant
Heavy Duty Diesel Type
MEP-8xx serpentine belt
Goodyear 4040355 Gatorback Serpentine Belt, Gates Micro-V AT K040355
MEP-8xx Fuel Tank Drain
Fuel Tank Well Nut A3816
MEP-802A 5kw generator
The military is currently using Optima Yelloptop 51R batteries x 2 in series for the 24 volt system
MEP-803A 10kw generator
The military is currently using Optima Redtop 34/78 batteries x 2 in series for the 24 volt system
Oil Type
Coolant
