fpchief
- 229
- 63
- South Alabama
Yep, it's just my carport. Thanks.Where did you find the pointed top bows? Home grown?
Looks good.
Looks good.
Installed new wood all around the bed. Can't wait to finally paint the whole truck.
Looks good.
G'day everyone,....
That pointed bows are the roof of the car-port the deuce is parked under.
Take a closer look.
Aussie.
DANG ! You got me with that "TIN ROOFED CARGO BED". I should go to bed earlier.Yep, it's just my carport. Thanks.
I thought the same thing until I opened the picture.DANG ! You got me with that "TIN ROOFED CARGO BED". I should go to bed earlier.
Looking more closely - without the fatigue - I can see it IS just your carport and NOT a Tin Roof over your Deuce's bed.
(EMBARRASSED!!!)
It's funny what the eyes will see at a glance.
Thanks.
I think its a great idea.DANG ! You got me with that "TIN ROOFED CARGO BED".
I got fooled by adrianspeeder the same way. He's got his "Frequent Flyer Miles" thread and I was swearing he was at 30,000 feet above farmland in his C-17 with the cockpit open(!!!!):It's funny what the eyes will see at a glance.
How you planning on cleaning the tank? Mines got some junk in it, and I need to drain it and clean it out, just not sure the best way to do it. I'd love to swap to an A3 tank, so i won't have issues again.Added air to the front tires, they were at 30 psiNow at 60psi I can actually steer the thing, go figure
Cleaning the tank and replacing fuel filters before the first fill-up is next on the list.
I'm here searching threads in it currently to see what others have doneHow you planning on cleaning the tank? Mines for some junk in it, and I need to drain it and clean it out, just not sure the best way to do it. I'd love to swap to an A3 tank, so i won't have issues again.
Was that the guy stranded at his mother's place? How'd it turn out?Met up with a fellow member and finally got my floor in the box welded up. Now the fun begins putting it all back together.
thanks. I put the lightbar on because of the old yellow 24v sealed beams were just horrible. I couldn't see a **** thing. that thing is BRIGHT. next just to get led turn signals and taillightsYour rig looks good, and I like the light bar AND the skull!
That's like the Hindu and Buddhist cosmology of time, which they measure in "Kalpas".Long story short, the copper air line from the compressor had been resting against the end of a bolt and after a matter of time (how many years?) the sharp thread of the bolt finally rubbed through the copper line causing the air leak.
By the time I was finished chasing down both air leaks, learning what I didn't know about ferrules and inserts and figuring out how to get a wrench/saw blade/clamp into impossibly small places, it was more than the mountains that needed wiping. Shoulda' started with my Kalpas first...That's like the Hindu and Buddhist cosmology of time, which they measure in "Kalpas".
Here't the definition of one kalpa:
Imagine a gigantic rocky mountain at the beginning of kalpa, approximately 16 x 16 x 16 miles (dwarfing Mount Everest). You take a small piece of silk and wipe the mountain once every 100 years. According to the Buddha, the mountain will be completely depleted even before the kalpa ends.
It's the study of Vedic literature through a Deuce-and-a-Half. Buddha would be proud.
