4 wheel drive low going forward or reverse which is better for pulling ?
Indyharleyguy
73
Carmel IN
Hi All,
I searched the forum and didn't find anything about this. My question is if you have to pull someone out from being stuck is there any difference if you pull them where you are going forward or pull them where you are going in reverse? I have a stock 1986 M1009.
Just wondered which way would have more power to really get someone unstuck? I assume going forward but we all know what happens when you assume. LOL
Thanks for the input
kblazer87
320
southeast Indiana
Stock first gear ration for the M1009 is 2.48 to 1 and reverse is 2.07 to 1, so all things equal more power is available pulling from the rear.
cucvrus
10,505
Jonestown Pennsylvania
I was told by the transmission shop that you should not work any automatic transmission in reverse. It seemed easy enough to follow them instructions. So I never questioned him further and investigayed any further. I just live by it. It made sense. Stick shift different story.
blueblaze
Chapleau, Ontario
With an automatic the torque converter actually multiplies your ratios by 1.5 and even 2 times in low gear. From a physics point of view, say someone was stuck in a ditch, I would hook myself up in the front and use reverse. When the strap is fully extended when snatching the stuck vehicle, it would pull the front end down, therefore capitalizing on the traction had by the front axle with engine weight etc. With the front end forced down right at the point where the strap gets tight, the wheels will get more downward force creating more traction. In my opinion the rear end of a truck has almost no traction anyways, especially if you have any diesel, plow or anything else weight bearing on the front end. Everyone has seen their neighbor with the 2wd diesel who cant even get out of the driveway with 2 inches of snow.
Mainsail
1,805
Puget Sound, WA
I can see better out the front, so to me that's better.
4Low is chock-full of torque as it is. If the truck doesn't have enough torque in 4Low going forward to do the job, you need a bigger tow vehicle.
Kaiserjeeps
North Idaho in the woods
Yes pull forward in low range. Ring and pinion gears are 20 percent weaker on the coast side of the ring gear tooth. The rear axle gear set is usually bigger than the front anyways. That's where the most strain will be pulling forward. Mays well give the work to the strongest parts.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
I have broken front axles doing the backwards thing. If possible (it isn't always) I recover going forward.
KsM715
142
St George Ks
Along with the gears being stronger while pulling from the rear, there's also a lot more crap for the hook or chain to go thru before it gets to you should something go wrong and things start flying around
nyoffroad
743
Rochester NY
I agree about pulling from the rear and going forward, but I've noticed that it seems my truck(s) have better traction in reverse. With that being said I've done both in HI and LO.
porkysplace
1,496
mid- michigan
Less chance of taking out the radiator pulling from the rear when things let loose also.
Indyharleyguy
73
Carmel IN
Thanks all. I like the idea of more things for a strap to go through and not hitting the radiator when puling from the rear. That's my plan from now on.
jpg
15
Boston, MA
I find it useful to be able to steer, both during and after the pull. Pulling from the front dramatically reduces your ability to steer, and massively increases the strain on your steering mechanisms. Pulling from the rear focuses any lateral strain on the rear axle, without involving all that vulnerable and relatively fragile steering gear.
