brian s
i got them from smittybilt depot $100.00 eachInfo on the seats? Kinda like the look and mine needs new seats
Maybe, during your off-season, you should just charge the little guy rent:The core looks good and seems to hold pressure, although I had to blow a BUNCH of fine shredded material out of it, looked like some wee critter was trying to make a home in there.
- You could ask top dollar what with the built-in exercise wheel.
Nice! I ended up having to buy a new 2nd gear with the holes already drilled in it from Memphis equipment. Couldn't find a machine shop that could drill or mill through mine, it's super hard even with carbide bits.I received the 5th gear kit today. I will be removing the trans over the weekend. Thank you Tom for the fast shipping. Can't wait to get it installed.
OK dumb new guy question..Used it to pick up a wood splitter from a friend and spent the better part of the day splitting from rounds:
Its your standard Habor Freight bed crane but modified to be more useful by the PO. He added some bearings to it to help it pivot under load, as well as put a mount on the bumper for it to help with pulling heads.OK dumb new guy question..
What kind of hoist is that? Is it aftermarket or made for the deuce from the military?
I have a similar crane that I'm hoping to eliminate the mounting foot and make a tube in the bed to receive it. I'd also like to put a mount on the front bumper for it so I can move things around with the truck and see what I'm doing.Its your standard Habor Freight bed crane but modified to be more useful by the PO. He added some bearings to it to help it pivot under load, as well as put a mount on the bumper for it to help with pulling heads.
Oh, and most importantly...he painted it OD
