- 3,871
- 504
- 83
- Gray Court SC
Behr and yes all lights wired and working.
Lights wired in piggyback through tractors rear lights or where the semi trailer would plug in?Behr and yes all lights wired and working.
They're wired in with tractor tail lights.Lights wired in piggyback through tractors rear lights or where the semi trailer would plug in?
Have fun!Go the truck and trailer all loaded up for 6 days of camping. Head out in the morning.
Yeah I have seen lots of twisted driveshafts from big rigs but the M931 has a very short shaft and good axles and he had 50,000 lbs+ on the truck so no slipping tires and a good full throttle pull something had to give and it is normally the transfer case or transmission on these trucks that will give up first. Not going to say they are weak but just the weakest link. As to anyone who thinks they are weak come watch me do wheelies in my 40,000 wrecker, they aren't weak but can be broken.I got a buddy who used to work on these 5-tons in the army, he was telling me they had alot of the t/case cracking because of rocking them back and forth trying to get them unstuck,but I can see a free spinning wheel catching traction causing extreme pressure on the t/case , that's alot of rotating inertia, most big trucks I have worked on usually twist or snap an axle when that happens
