K&N Air filter setup
hirollin87
9
Raymond MS
Can someone help me find the post where someone has a K&N plumbed under the hood of an A2 truck? I saw it somewhere on here but can not seem to find it anymore. Thanks
VPed
304
Clint, TX
AFE sells dry reusable high flow filters that are much better at stopping dirt than the oiled K&Ns.
Ddmk18
James Creek PA
Yes because I added a 25 gallon hydraulic tank where the original filter was and plumbed it around the tank to retain the original air stack. image.jpg
Ddmk18
James Creek PA
Ok the filter I used was K&N 38-2006S. It has 6 inch inlet I used a 5 to 6 inch coupler then it has a 5 inch outlet which I ran 5 inch the whole way into the turbo. As far as air restriction goes I never hooked up the original gauge again. I know it had to be better because I had her turned up pretty good and the egts where lower with that filter setup than with the factory filter. More air in = lower egts.
