Howdy,
For those thinking about swapping a bunch of the screws on your MEP-802/803
MEP-8xx stainless steel screw information
The main screw used 80% of locations on the panels
#10-32 x 1/2" Hex - Unslotted Drive Indented Hex Washer Head Grade 18-8 Stainless Steel Machine Screw
#10 18-8 Stainless Steel Medium Split Lock Washer
#10 18-8 Stainless Steel Small OD Flat Washer
#10-32 Grade 18-8 Stainless Steel with External Tooth Lockwasher K-Lock Nut
The other large screws are
1/4"-20 x 3/4" Hex - Unslotted Drive Indented Hex Washer Head Grade 18-8 Stainless Steel Machine Screw
1/4" 18-8 Stainless Steel Small OD Flat Washer
1/4"-20 Grade 18-8 Stainless Steel with External Tooth Lockwasher K-Lock Nut
The look is the exact same which you have currently. The main #10 screw at some locations use just the screw itself, some with a washer, and some other with a lock washer and washer.
I ordered the below, because of the size of packs they sell.
50 #10-32 x 1/2" screws
50 #10 washers
50 #10 split lock washers
50 #10 nuts w/keeper lock (The amount will depend on what year your unit was built) Some year they switched over to having a majority with cage nuts.
This still might not cover them all. I do not know the exact count that you will need.
The larger ones will be around 20 pieces.
50 #10 washers
