rustystud
- 2,760
- Woodinville, Washington
Again I ask you, where is the documentation ? The anger I have is all this BAD information your spouting off ! I don't want others who don't know better to take this information as gospel. You can say the moon is made up of green cheese and ham but it doesn't make it so. Show use in writing all this information you keep saying ! It must be out there if these "reps" you say talk with you.Many of the oil companies had to remove all the ZDDP from their oils so they could start using their new friction modifiers. Like I said the ZDDP and the newer friction modifiers don't play well together. You may have gone through this rodeo before, just as I have, but you also need to stay up to date. As of now I own and run on a regular basis 11 engines with flat tappet lifters, both gas and diesel. I have experienced no camshaft wear while using off the shelf oils, and I am not using any additive. The PSI figure came from a wear bar test. I'm not a big fan of that test, but thought it deserved some merit. I do watch YouTube sometimes, but only for a laugh. I've had the reps from Valvoline and Mobil on the phone more than a few times. That's where I've received alot of my info from. Also the fact that you are responding to my posts with anger only means that you feel that my posts contain information that has merit. Though you may not agree with it.
