ok the wiring if not noticed is heavy gauge 50 amp fireproof cable.
QUOTE]
Hi, Don't know about over there, but I did some insurance claim inspecting, and frankly, if your truck had an incident, the major carriers in this country would deny your claim.
The battery box in post 1 appears to show multiple loose, free, unsupported wires resting on the batteries or the edge of the metal battery box without protection. Wires should be properly supported and in a proper loom, not resting on the batteries or edge of metal battery tray itself. Resting inline fuses on a battery, where acid vapors may be present is also cause for concern.
There appear to be multiple splices with unraveling tape, and a damaged cloth covered wire in contact with the battery at the rear of the picture. There is a preponderance of red wire powering what appear to be different functions. It is standard practice to use different colored wire for different functions.
Over here, we use the IASCA wire size chart or equal for automotive wire sizing. As you can see, over 4 feet, 50 amps requires a minimum of 8 gauge, and over 10 feet, 6 gauge.
System Amperage | 0-4 ft. | 4-7 ft. | 7-10 ft. | 10-13 ft. | 13-16 ft. | 16-19 ft. | 19-22 ft. | 22-28 ft. |
0 - 20 | 14 | 12 | 12 | 10 | 10 | 8 | 8 | 8 |
20-35 | 12 | 10 | 8 | 8 | 6 | 6 | 6 | 4 |
35-50 | 10 | 8 | 8 | 6 | 4 | 4 | 4 | 4 |
50-65 | 8 | 8 | 6 | 4 | 4 | 4 | 4 | 2 |
68-85 | 6 | 6 | 4 | 4 | 2 | 2 | 2 | 0 |
85-105 | 6 | 6 | 4 | 2 | 2 | 2 | 2 | 0 |
105-125 | 4 | 4 | 4 | 2 | 0 | 0 | 0 | 0 |
125-150 | 2 | 2 | 2 | 0 | 0 | 0 | 0 | 00 |
I am sure your methods have worked for you, but over here, most insurers would consider them unacceptable.
