Hx 50 turbo
profo
74
jeanerette,la
Has anyone mounted one on their 5 ton and if you did , did the EGT's go down, still flipping quarters to do mine.
Thanks
74M35A2
340
Livonia, MI
I'm watching this closely, been wondering and wanting to do same, with the big full size Volvo charge air cooler up front like 4xdesign did and gut the factory after-cooler which chokes out at the 300hp mark.....
162tcat
Washington
I think with the hx 50 and FMIC the 8.3 could do a reliable 350 horse without much worry about egt. I'd still run a gauge but I would feel very safe with that setup. Now it's just the time and money to do it! If I could only find a good deal on the hx 50...
profo
74
jeanerette,la
They are cheap through parts yards. Get a used one, put a kit in it, and be done.
I can get a rebuilt one for about 300 and already have a new Chinese clone that I don't want to put on, I don't have room for the inter cooler with the Ac condenser in front so I am trying to see if someone done it without and if it helps before I spend the money if not needed.
Thanks Marty
nevrenufhp
Sacramento
A 50 will just be slow to spool up, unless you change injectors too. The old 4 hole spray pattern in these are terrible, and the biggest reason for high EGT(even without making fuel adjustments).
74M35A2
340
Livonia, MI
Agree. Tell us more about injector options (separate thread). Are the marine ones a bad option like the diesel boards say they are in 5.9L applications (wrong spray angle = idle haze, smoke, and high EGT's)? I think you sell 8.3 injectors, are they marine and how are they on idle haze, smoke, and EGT vs power increase? Thanks.
profo
74
jeanerette,la
Yes a lil more info would be great I am not looking for a race truck but I do have a load all the time, camper wind resistance and would like to pull a trailer which weighs about 10k when fully loaded with me, tried pulling it and at 60 mph I sustain right at 1150-1200 on flat level ground and this is just to hot for comfort it will go to 1300 on overpasses and that's after I usually shift down to 5th or 4 forth depending on steepness. I tried a modified turbo from a (turbo guy dont want to say his name) which was supposed to be a new modified holset and it seemed that the temp increased, without changing anything , but I am not sure about the guys work , he said I would be getting a new turbo modified for more flow and the turbo looked like it was off a wreaked truck, and I don't want to go down that lane again would prefer to buy a genuine holset turbo new or rebuilt from a reparable company if it would work.
nevrenufhp
Sacramento
Ok. I'll add it to a new thread. I'm coming up with a few different sizes to use. The first one is a stock replacement that I'm working on the final details with DWC. He agreed to be the guinea pig.
profo
74
jeanerette,la
Sounds great i even give you my Hx 50 Chinese clone if you like or the wreaked truck version if you like, I even have two new hx35's if needed that would trade for a good proven HX 50.
