TexAndy
- 15
- 38
- Bee County, Texas
Did you have the Macguyver theme song playing in your brain when you got it fired up? ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Green lights as in on the transmission controller? Yes, if you follow along in the thread, that is the problem we had to overcome. Now sounds like you too. If your diagnostics lead you to believe your controller is bad, and Suprman can't save the day like he did for us, send your controller to transmissioninstruments.com.NDT you are the man!
Question, when you hit the master power switch are those green lights supposed to come on? Because on mine they don't light up.
Talk about tranny selector etc. starts at post #124 which is on page 13 on my puter screenGreen lights as in on the transmission controller? Yes, if you follow along in the thread, that is the problem we had to overcome. Now sounds like you too. If your diagnostics lead you to believe your controller is bad, and Suprman can't save the day like he did for us, send your controller to transmissioninstruments.com.
My problem is going to be having NDT 4 hours away after I get the truck home and having to figure it out myself. Fortunarely Keith_J is close and he's a wiz at electrical too. Me, I'm a "give me the new part and I'll put it on" kind of guy without the sleuthing ability.That's how it needs to be
I'm starting the AC install as soon as I get the truck home. I'm still debating the gear change. I think it's a no brainer for the A1s but wonder if it's that beneficial with the underpowered 3116.high speed gears and ac install this summer , I should be good to go !
"Underpowered" compared to the C7, or at least the reports I've read. I was perfectly happy with upper 50s in my 923A2 so I'm sure I'll be happy with the LMTV. I do have a little concern about speed drop if I get a M1082 to pull. I'd really like to build a pop-up style camper in one and head to Big Bend or Arches National Park or any other place where I could drive the 1078 around and camp at the same time.I don't need to go faster than 57 in my lmtv. Compared to driving the older mil trucks the lmtv 3116 dosnt feel underpowered at all. I like the low range pulling power which you would loose with a gear change. If I need to go fast I have other vehicles for that.
