- 4,443
- 3,759
- Fort Worth, Texas
Some of you may know I've been working on getting an M925 running for a while but no luck. I went ahead and pulled the trigger on an engine swap then tore into the seized engine. Cylinder 3 & 4 were solid, 3 being the main issue as the valves were stuck open and let in water. The valves are frozen in place so well that a mini-sludge wont convince them to move. This was an 04 overhaul at the Central European Command with less than 24K miles on the speedometer. Paperwork indicated either 07 or 09 turn in date (faded).
Lesson: The worst thing you can do is NOT play with your toys.
Hate to say it but don't give up your day job!
R O F L M B O !!!
