high horsepower & extremely high torque transmissons?
Jbulach
2,396
Sunman Indiana
You definitely need to make sure you communicate this to your builders. That's going to add a whole different equation to the giant ball of wax!!! Weight is weight .... But your talking unsprung, rotating mass weight! You need to rethink those tires, there are a lot of awesome options out there...
Ibexe666
Florence, South Carolina
The reason i picked the tires is because of them being solid rubber 60in and super wide with tread depths of 7.6 in if you have any idea on other tires like that let me know :) and i am going to be doing most of the building unless i need help thats why im trying to get lists and stuff together
Jbulach
2,396
Sunman Indiana
You've got two choices.... Get to the bottom, or float on top... The HP/TQ numbers your talking won't come close to floating a 30k rig, 12k of which are tires!
Your going to the bottom. Stay as light and keep the tire speed as fast as possible
M925A2 with dump hoist
Ibexe666
PHP:
I thought that but width of the overall vehicle come into play monster truck tires are usually 45" wide most im willing to go is 25" wide tires. The axles are going to be as shorted as much as possible to try and fit the tires as close to the width of the vehicle to prevent rubbing its gonna be lifed a fair bit
Jbulach
2,396
Sunman Indiana
OK, I would forget puncture proof, and go with some bad ass r2's, they will break any drivetrain you can throw at them with your engine #s
