- 1,450
- 126
- 63
- Gray, GA
I replaced the inner axle seal and retainer on the right front. I've replaced the seal a couple times already, and still had a leak, so I figured it might be a retainer issue instead. Time will tell.
I made a seal installer to put the seals in. Setting them without damaging them, with the knuckle still in place, can be a challenge. I used the bridge from a massive jaw puller, that was missing pieces, to wedge inside the knuckle. It fit and worked perfectly. The large pushbolt is threaded all the way back and a custom made seal installer is inserted into the hole. The pushbolt pushes the installer while the bridge is squarely wedged in the knuckle housing.
The retainer installation required some modification to the seal installer part. It was a little light duty and I brought out the welder to beef it up a bit. I put it in place and turned the screw until the retainer was properly seated. It pressed it in nice and square and with minimal effort. The little time I spend putting this together was well worth it.
. I noticed my new horn button isn't working so I'll be taking that apart in the next few days. The wire in the column probably just came loose. Next up will probably be doing my floor mat and new insulation on the hardtop, then troop seat boards. One step at a time this truck is slowly becoming new again.
