scottmandu
- 35
- 28
- Texas
Sounds like you have low refrigerant or an expansion valve issue. What are your pressures? Also how many pounds of Freon did you put in the system?
The amount of refrigerant is relative to the size of the system. First taking it to a local shop that put 8 lbs in it and not being satisfied with the results. I contacted red dot who felt that was to much and recommended a specialty AC shop 70 miles away in Tampa which specializes in custom AC installations for over 30 years. I took it there and they vacuumed the the system and started from scratch and watched the pressures while filling the system back up and put the same amount back into it within a few ounces and he was very pleased with the pressures and called it perfect.
Unfortunately I don't know the symptoms of a bad expansion valve.
Do you mind taking a picture of it with the cab down? I would really appreciate it.I haven't seen any additional mud or such get into the engine compartment.
I'm in Wauchula.
Everything looks brand-spanking new; like it was sitting on a showroom floor. That's nice.
