Gu3
- 0
- 0
- Tres Piedras, NM
This is my first time to work on/repair a military vehicle, so thought I would post some pics of pulling and repairing the transfer case. If anyone knows where I can find diagrams or an assembly/disassembly guide, please let me know.
Unbolted the bed and slid it back far enough to access the transfer case.
hoisted down the spare, unbolted and removed the hoist.
disconnected all air lines, wires, drive shafts and mounting bolts, then lifted out the transfer case.
Began disassembly of donor transfer
case.
The donor case had a bad front output shaft brg, and the 2008 rebuilt case only had 1975 miles, but attempted theft of the truck caused a broken input shaft. I figured I would swap in the needed parts into the newer case since it had less miles on it, even though the gears of the donor appear to be in great condition.
I don't have a diagram or instructions, but have been turning wrenches for near 38 years on and off the job, so hopefully I can make a go of it. Already had to purchase a 3/4 drive impact socket set for some of the work. One of the important issues will be getting the shims correct for the proper clearance, but I can use a dial indicator to measure the back space on the existing shafts prior to disassembly and put it back to those clearances.
Donor case split, and ready to clean up and use input shaft.
More to come.
case.
More to come.
