YS Carburetor for A1
dodjh
14
Central, MS.
After cranking and idling, (which is no problem) if I press the gas pedal a little more the engine starts to die. If I hold it there it will die.
If I push more it catches and runs fine. The rpms just past idle, 700 - 800, is where it pulls down.
So if I remove my foot from the accelerator pedal and just let the jeep pull, it's fine. But if I start idling up a hill and need more fuel, when l press the accelerator just a little to make it up, it will start to die until I push the pedal and give it more fuel than is needed.
I have two inline filters, 1 before the fuel pump and one between fuel pump and carburetor. They both fill up with fuel.
What is causing this?
Thanks
NDT
7,138
Camp Wood/LC, TX
Needs a kit. Make sure you probe out all the drilled passages throughout the body. I suspect one of the diaphragms in the lower body is stuck or punctured.
dodjh
14
Central, MS.
There was a kit put in it about 7 to 8 months ago, but I agree it has to be a diaphragm or a clogged jet. The fuel tank does have some particles in it which show up in the first fuel filter sometimes. The jeep will die when that filter is plugged up and I have to remove the line and use compressed air or mouth and blow back through the fuel tank. This time I noticed the second filter, between the fuel pump and carburetor, had some black stain on the inside side of the filter. Some trash must have gotten past it into the carburetor.
If trash made it to the 2nd fuel filter wouldn't there be trash in the fuel pump?
Thank you for your insight and feedback.
