Fuel tank Drain Bolt
SierraHotel
Haymarket, Virginia
Anyone know of a place to procure one for a M35A2...or barring that, the thread pitch/size and the bolt size so I can get one commercially? I'm usually pretty good at searching, but I have not A) found one in my internet searching, nor B) found my original that appears to have grown lil' legs and taken a stroll. I'd really rather not get one of those expanding plugs.
  • Like
Reactions: HDN
rustystud
3,394
Woodinville, Washington
Are you talking about the drain plug ? It is just a standard 1/2" NPT plug. I went with brass since my last one decided to rust itself in place.
Kharville
Clinton LA
Does this fuel tank drain plug get any type of sealant on the threads when replaced or just screwed in tight?
Same question for the transfer case drain plug. Mine is tight but dripping oil from the transfer case.
Barrman
2,244
Giddings, Texas
I like Permatex Number 2 gasket maker for those plugs. The white tube with the really sticky black goo. Being NPT, they shouldn't need sealant, but as pointed out sometimes they do. I have never used it on my fuel tanks though. Just the gear oil plugs.
rustystud
3,394
Like "jbayer" said. Teflon tape is good. I prefer to use the paste myself. Gets in the threads better.
  • Like
Reactions: HDN
